right i have just put my rebuilt engine back into my paseo and i can not get the petrol pump to prime or any spark, the alarm is not working so i beleve it could be that. any help would be great or some contact names to sort me out. :cacker:
oh yeah just to let you know i brought the car with no engine in. all electic work, i.e the dash, is working.
the alarm may need resetting it may have a secret code button on it. do you know what type of alarm or what make it is? you could give secure a car in stafford a call on 01785 606606 they are alarm and stereo experts i used to work for them on the stereo side.
Jim
its the standard toyota alarm.
mine paseo is the st model does any one know if it has an immobilezier?
yes it has an immobiliser and an alarm, have u changed the ecu?
not change the ecu all standard.
i have got the car to open with the key fob but still can't close it and the fuel pump is still not coming in so is still immodiliezied.
Check the fuel pump relay and if necessary bypass it. The immobilizer just kills power to the fuel pump so if you get rid of that then it should work.
Not sure if the immobilizer in question is 2 circuit? if it is then it is likely that the other circuit that is isolated is the ignition. You will need to bypass this relay as well and then it should work.
Toyota ecu's are separate to the alarm boxes (unlike volkswagens!) so if you bypass the two circuits you should be able to get it to work, then need to worry about the alarm.
hope this helps
have a nice day
sanj
also forgot to add, make sure the Battery has enough juice so that the receiver on the alarm works.
thanks i am going to see if i can get the key fob reprogrammed or i will get an updated cat 1 alarm and see if they pull it out and fit there new one will it work
