Toad Ai606
sub-son1c
Hi guys,
i am seriously thinking of getting a toad Ai606 alarm/imobilser, as i wanted a good cat 1 alarm... any thoughts on this model or any other cat 1 alarm/imobilisers?
and has anybody any idea were on the 1994 celica gt4 st205 the factory fitted imobilser is?
cheers guys
Hi Mate,
As you can see from my sig I have a MR2, I have had a AI606 fitted to mine and I am well impressed with the unit.
I find it an easy to use but very effective system which you can buy add on form, I bought the unit of eBay for £120 and had it fitted by a mate.
Hope this helps.
Dave :thumbsup:
thanks m8,
thats what i needed, just a bit of positive feedback from someone who has one, so if they are as good and problem free as you say then i think it will be the way to go for me, now all i need to know if anybody has any idea were the factory fitted imobiliser is situated so i can replace it with the Toad unit?.
thanks dudeone for your contribution its what i needed :)
ai606 requires a 2 stage shock sensor unit ( sold separate at around £35 ), i have 1 fitted to my gt4 , alarm and immobilser arms after 20 seconds of switching the engine off .very good system.
Would this be affected by a turbo timer?. My car uses a toad A50 system in conjunction with a meta immobiliser but it`s an old system and could do with upgrading. The 606 is in the frame as it uses some of the same components as the A50 and will be easier to install. :thumbsup:
it does dak as the ai606 has anti hijack also.and when the engine switches off it will open the doors.So its something that needs to be looked into.
Righto. :thumbsup: Cheers marc. :D
i just sit for 2 minutes scratching me ar** :lol:
The stock alarm is behined the glove compartment on the 1995 gt. I got the toad, its ace, also alot of the features such as anti hijak etc can be switched off.
