Speedo Meter,dash,indicators,brake Lights Etc
chursy
hey guys
was changing the dash bulbs and unfortnatley left the ignition on....which cased all the lights mentioned not to work...its one of the big fuses cause i checked all the smaller ones... Have got the big headlamp fuse out....but Halfords havent got it....would like to know whats wrong if its not the fuse...dont think all the bulbs would have blown up...so can anyone please help me with this...and where do i get the parts if i need to....will be waiting for the reply.... I have the toyota avenses 98....GS model
solder a small length of wire on both legs of a 20 amp standard fuse , bridge the gap of the blown fuse and see if they work again. :thumbsup:
Hey
so do you think that its the fuse for sure....cause i have the fuse...cant really see the broken think cause its gota a cap on top.....but u rekon its the fuse....for sure?? cause i can check the the fuse...with a mate of mine..he has the same car...but if tis the fuse that will repair it as u are saying
all i'm saying is try this before you buy a fuse to eliminate the fuse from the equation.
yaa willl do that anyways...was wondering if you think its something else...that cause the lights...apart from the relay its self....? or you dont know ? thats what i have bin asking in my past three posts...if its not the relay thn what else could it be....
the headlights and rear lights work on a left and right basis ,and not front and rear.if non are working its highly unlikely to be 1 of the main fuses more likely the smaller ones as they are smaller rating and will pop first .do you have any electrics to the car at all ??? is it turning over ? did you not just flatten the Battery for instance.all the things you mention arnt even on the same circuits so i find it highly unlikely that all have gone off due to a single fuse blowing,i mean if you were driving in the dark and that fuse blew imagine what would happen, toyota are not that silly.
[Hey...
welll...all the smaller fuse are working...now...only the left headlight is working...and the dash and speedometer indicators arent working....the lights when u turn on the ignition like the ABs and smallers one that come on at the bottom of the speedometer are working...Havetn checked all the smaller ones....they are all working fine...soo...dont really know what the problem is...i thought it was the main relay for the headlamps.....cause its all links to the single clcik when you switch the headlamps on from....
