I Think My Turbo Has Gone
white smoke is turbo. black smoke is fuel, blue smoke is rings
Sorry to hear about the turbo fella, but it's just one of those things i'm afraid. :(
Yep Stu oh well :(
I noticed alot of oil around the ring of the turbo, a few pools of oil under neath the turbo
and abit of play in the turbo bearing.. couldnt get a good enough look at the blades though.
Its been a good turbo though 10 years old
Got all the belts ready to go on, car is currently in garage
turbo is due today aswell so waiting for that, once the turbo
is here i can get them to get the car finished for today
or tomorrow
Come on turbo hurry up ;)
Not long mate.
You should see it hold a bit more boost when it's done too! :thumbsup:
Keep ya !Removed! up :D
Things going down hill now dad went to check on car
on his way through and apparantly the turbo is off
and he doesnt see anything wrong with it , the engine
is almost completely apart and still the belts have to be done!
If it isnt the turbo ive just spent £500 on a new turbo
because thats what other people told me it was
especially turbo TECHNICS :ffs:
I just hope it was the old turbo and nothing
much worse
edit : if the turbo Seals are gone would this also cause turbo failure?
Was there a lot of oil in the inlet/intercooler pipes? That's a sure fire way to tell if the seals are gone.
get your dad or someone to do a compression check to eliminate piston ring failure
In the intercooler pipes was oil around the inside like put your finger in
and it will end up on your finger, my dad says the engine is fine
The whole center spindal of the turbo you can hold it and move it from side to side much more than you can the new one
check to make sure that no blades have broken off and gone through the engine. seen this a few times on std ct turbos.
hope everything is fine
The inlet Fan of the turbo can be moved from side to side by holding the center piece of the fan and it makes a squeek sound.
The fan on the other side makes a slight click sound and sometimes squeeks
when turned
The bottom end of the turbo on the inlet side is Covered in oil
Bad news!!! I know the squeaking noise.... when it half heartedly spools up it sounds almost like a siren! I have both go at once on my TT when a boost hose fell off causing the engine (and therefore the turbos oil supply) to die :crybaby: had 17 years service and were fine untill then!
Turbo technics are a very good firm to deal with!!!! I think my CT-26 on my sngle turbo is due soon... how much did they quote you?
alot more than i expected, i got £495 nearly £500!! for a single entry turbo
but mines a twin entry hence £595 , you get a nice piece of paper saying
you get a surcharge of £250 for your old turbo which makes you think
your getting the original price dropped. BUT NO this surcharge was already
added in the price :ffs: :ffs:
fing garage, car is still in parts still not done 3 days later
and the guy doing it is moaning about it , THEN WHY
OFFER TO DO THE WORK THEN!!! W**KERS
Took 3 days just got a phone call that its finished belts changed and new turbo fitted and guess what they said
They got it upto 3000rpm and the car is very juddery
wtf is going on, and i cant get to see whats up with it
till tomorrow :roll:
Edit : had a further speak with them apparantly the turbo
does sound like its going round and there the BOV is working
as it was not doing that before, also the turbo is only going up
to 0BAR as the boost controller was set to the bare minimum
This make sense?? , the other turbo would shoot up to 0.5 bar
how ever low the boost controller was set too.
I think the best thing is me picking it up tomorrow
as i know my own car and see whats up with it then report here,
fancy them finishing it just before it closes
