Battery Drain
for some reason my Battery goes flat till the ampmeter reads half, and it wont start obviously, but i get pushed and started its ok and recharges the Battery, but after a 2 days it goes to halfway again......is my Battery dud or is somethin shorting it out????
the bottom engine mount is badly worn if that makes a difference????
:help:
Sounds like the Battery has had it really, have you tried charging it? an altenator isnt meant to fully charge a dead Battery, they are only really meant to maintain the charge, try giving it a good charge and see how it goes
