Oil Leak!
Hi, when replacing the rocker cover gasket, what other seals, gaskets, nuts or bolts should I replace at the same time. Any advice would be much appreciated. Thanks.
none as far as i know need to be replaced when just removing the rocker cover ?!?!
just need to replace the gasket and thats it...if any bolts are starting to wear...could change them to prevent any problems in the future....
I would change the seal between the distributor and the head/rocker cover, it should be visible when you take the rocker cover off, its also a culprit for oil leaks. You will need to remove the distributor, so make sure you mark its postion before you undo the bolt, otherwise your timing will be out.
Cheers people. Will probably change gasket and dizzy seal to be on safe side.
