Baffled, 17' Rims Wont Fit.
just tried to fit my 17's on the front but the suspension sits on the tyre.
how'd everyone else do it?????
Sounds odd, i've got 17's on a REV 2 with standard billies, and lowering springs, they sit fine :unsure:
what size tyres do you have? I'm on 215/40's
got 215/45's, it's not like they only just touch them, the car is sitting on them!
What springs/dampers have you got on ?
thats strange?
dunno im running 17's fine. And i know others have 18's
something sounds wrong, I dunno if you need tougher dampers or springs really :unsure:
the springs/shocks are standard, does your shock sit behind the alloy when on?
you are putting the wheel in the big arch area of the car right?
Yes the shock has to be behind the wheel when on, and I just about fit 2 fingers between the tyre and the arch edge :unsure:
don't get ya
I mean on my set up, with the 17's on I can push 2 fingers into the gap at the top of the tyre to the arch, i.e theres plenty of room there
what offset have you got, if you have the wrong offset the wheels might sit too far in...just a thought ?? <_<
migh tneed spacers :thumbsup:
what about behind the wheel, how much gap between the rim and shock?
You could have hit the nail on the head there Bound :thumbsup: hope that solves it aa120n
I hate it when something that seems strait forward ends up a nightmare....like getting out of bed in the morning :rolleyes:
there off an lexus IS 200, i was told that they'd fit. where can i get spacers from?
most wheel / tyre specilists will do spacers, look on the net as well, or ask at rogue systems.
they might fit as in the stud arrangement, but the offsets for differnt car manufactures are raerly the same.
ie vw wheels fit on a vauxhall, but they are a wider offset on a vw, so if you put em on a vauxhall, they will hit the arches. and if you put vauxhall wheels on a vw, they might hit the suspension / the inner wing, so you will need spacers !!
aa120n Have a search through the forum, I'm sure someone else on here is running the same hoops, I'm sure there was a post all about it not so long ago, hope that helps :unsure:
i'll have check now, cheers
I thought I read that IS200's didn't fit.
And I read that they did?
lol
It'll definitely be your offset.
You need to be very careful getting the offset right.
You will need a different offset on a 17 x 7J wheel to a 17 x 8J wheel... if you want the front face sitting in exactly the same place.
Have I just made that confusing??? :wacko:
it is your tyres, as i sold a MR2 to Gordon Hutchinson and he has the Lexus IS200 wheels on his Mr2
i have those wheels on. and they fit. even with the stock rubbers on which were 215/45R17. thats pretty weird that the tires are touching the suspension. mine were really close to touching. probably about a centimeter from it or something. only time i heard rubbing is if there was a stone between the tread or i ran over some mud. if u have spare money, get a smaller profile tire for the fronts. like 205s.
