Traction Control?
albundy
my traction control is not working iv only had the car nearly 4 weeks now and this is the first thing thats went wrong is there any ideas on wot it cld b? i will need to take it to the garage as its under waranty just wonderin if any1 else had had similar probs iv got a 02 cts with 15000 miles cheers
well it still wheelspins wen u pull away and wen i start the car it says traction control is off and the 3 yellow lights stay on 4 5 secs so i dunno wots up with it
Its supposed to do that mate. If it stays on however, just press the traction control button and it should be on then. :thumbsup:
iv tried swithching it off then on again but it still spins are there any sensors that may have came off or sumthing?
I remember having the same problem (or nearly the same) when I first bought my CTS. Took it back to the dealer and had it fixed. They said that traction and VSC system needed calibration.
So it is better to take it to your local garage to see if it is something similar to mine that causes trouble with these systems.
