Camry Hesitates
teri_maki
I have a camry 95 about 127k miles on it. Recently had the front exhaust pipe replaced as it was broken and was leaking.
The front pipe comes with the catalyst.
After that I started to have trouble ...
Cold start is fine and driving around for 5-10 mts it starts to hesitates.. when cars comes to a halt (like a stop sign or signal light) it also stalls sometimes.
I changed the spark plugs, the wires and also cleaned the throtle body...still the same problem
Any ideas ???
Have the diagnostics checked, symptoms could be related to Oxygen sensor in the exhaust either having been damaged or disturbed by the repair.
