Uk Tt
DBR
Hi all, quick question
i have been to see a 93' (on 'L'), UK TT, i am going to buy this car but i need t know a couple of things:
May sound Thick But:
- How do you get traction control on and off, and how can you tell if it is on/off????
(couldn't see any warning light going on or off on dash when i pressed button)
-How do you get the front spoiler down.
(pressed button whilst stationary, nothing happened am i doing something wrong?)
- does this model have abs.
(there was no dash light for abs)
please let me know, your help much appreciated!
DBR ;)
Sounds like you have a few blown bulbs or fuses as there are lights on the dash and surrounds for all the above apart from the active spoiler which is done automatically when over a set speed.
Hope that helps
The TRC button under the stereo, when you push it in you will get a light come up on the right of the dash which says its off - for your own safety never turn this off :thumbsup::lol:
This is a weird one, if you have been driving it seems to lock into auto mode and you cannot control it manually. I find to get it to drop manually its best to unlock the car, turn the key to the ignition but dont start it. Press the button and it should drop :D
Every UK Spec Car has ABS :thumbsup:
DBR  ;)
Whilst driving this activates at around 60mph+ (green light will come out besides the button to show it is down) and return to standby mode once you've slowed down to around the 45 mark.
If you want to bring it down for a photoshoot, as Leeky says, with the engine off, turn the key, so all dash lights come on, wait a second or two and push the spoiler down button. Green light will come on and spoiler will come down. When you start the car, it'll go back into hiding!!
DBR  ;)
cheers for the reply m8, ill giv it a try!!!
cheers for the help m8, all sorted know! :thumbsup:
cheers m8 all sorted :thumbsup:
