Break Fluid/coolant Change - T-spirit 2002
HitenV
I need todo an Break Fluid / Coolant change on my Corolla T-Spirit 1.6 2002. The car is out of warrenty and the dealer is asking too much todo this work. Is this a fairly straight forward process - I would be grateful if anyone could give me a brief outline of what I need todo.
Thanks,
H.
By a decent brake fluid like DOT 4 and above and pay an indepentant garage to do it. I shouldn't cost too much. I would say you need about 2 to 3 litres to do the job.
Same with the coolant really.
To changes the Brakefluid you need only 1 liter thats enough
the Coolant you need about 5 liters
Thanks all - I'm grateful for your help!
Toyota recommend changing the Break Fluid after the 2nd service - however, is this actually necessary or will a top up do?
Definitely a vital change and as important as an oil change.
I agree :thumbsup:
