Wheel Spacers
yaris-on-18's
anyone know where i can get some extended wheel bolts and spacers for the yaris. need the spacers to be about an inch maybe inch and a quarter
spacers arnt the best of things to use, if the wheel wont go on, then its not ment to be
try kevin at envy tho, think he has some
get a few sets of wheel bearings too. 5mm spacers can destroy a bearing in about 40k. so imagine what 35 mm is going to do. you do the math.......................... oh yeah and thats each wheel.
i beliveve ive already suggesteed what you could do with it on another thread. so i wont say it again ;)
Be prepared to replace the bearings as Chris said... Easy job, might get a bit tedious after a while..  :(
And be prepared to have a shudder throughout the car.. these spacers cause no end of problems in that department.. i speak as a Tyre fitter.. i see it every week.. SPACERS?? NOOOOOOOOO!!!
with that amount of spacing itll render the car as show use only
the bearing will collapse! let alone wear out!
the wheels are on i just need them to sit further out from the hub so they dont look so lost in the arches
get rid of the arches then! car will look 100% better and you won't risk life and limb with spacers............... just a thought
