Hello Evrbody! Pls help me to choose a rear silencer! Wich one will give the greatest sound to my Paseo 1,5 5E-FHE? :D
anything less than a magnaflow will give a deafening horrible-sounding raspy glass-shattering tone. trust me. :hokus-pokus: experienced firsthand
What about Remus?
theyre a good company...apparently their mufflers give you a lower " bassier " sound, which is good. im getting one hopefully soon enough, they are a bit expensive though seeing as they are a reputable company (i.e. they actually race, and have done so for years, aint one of those *****ty ***** boyracer end cans which are made from a few coke cans)
c'mon Riko, tell the truth. they're VERY expensive
shhh, he doesn't know ;)
actually, I'm from Moscow and as far as I know shops do not offer remus mufflers designed for Paseo here. But from the other hand universal mufflers prices begin from 90$ and go up to 200 or smth/// I guess 150-200$-one would be a good choice!?<_< magnaflow mufflers ain't cheaper anyway.
true, but the sound is worth it trust me. I've had experiences with both styles of mufflers, i'd take my magnaflow over some straight-through can any day.. plus, paying a little more for something you can get is better than paying a lot more for something you can't get.
So, wich model of magnaflow should I look at?
mine is a simple straight flowing muffler with an offset tip. it's ovular with dimensions of i think 4x9x20 tip to tip. 2.5" inlet, 2.5" outlet with an adaptor welded on to the stock exhaust.
why dont you consider making a custom exaust with just a little backpressure? Mine's a freeflow custom made backbox and it makes a roar no lion can whistle :)
PM me I can fix you up with one. Pretty good quality too , and cheap.
there's a difference between a custom exhaust, and an aftermarket muffler. the whole exhaust requires new larger-bore tubing and mandrel bends (if you want a good one), but if you go much larger than stock, you lose all sorts of torque.
yeh, what dev said. not to just ignore what you say mario but sticking a backbox on the end of your exhaust will do very little if anything. if you want something worthwhile (for a paseo....powerwise) you go with slightly larger than stock bore the full length of the system + mandrel bends to maintain some backpressure whilst still provide a greater flow. and i think that by doing the whole system not only will it be slightly louder but "bassier" too as you are not squeezing air through a small tube then outuva huge hole (which makes the bee-like tinny sound)
and i dunno, i dont like " free flow " backboxes....on a car like the 'seo it'd just make it sound tinny and bee-like, perhaps since your car is turbocharged itll produced a different sound as the turbocharger itself actually acts as a muffler, quieting the sound and perhaps creating a different effect
that's a different story, if it's turbocharged, the turbo gives backpressure, you don't need to worry about it in the exhaust.
yeh i know, but i mean if you stick a " straight through " backbox on a turbo then its less likely you'll get the !Removed! / bee sound because the turbo provides some muffling (i.e. backpressure)
ah, i wasn't talking about the sound, merely the backpressure.
