Hi all
Can anyone help with this one - I recently put my Lucida in for a cam belt change, and it now suffers from a serious lack of power and acceleration between about 50-60 mph which it didn't do before! Also, if I try and accelerate more to overcome this, it kicks out loads of smoke from the exhaust. Around town or above these speeds it seems fine! :unsure:
Posted (edited)
Hi all
:unsure:
hi there, snap having the same problem,but my fault diognosis light is coming on as well,flash code 35, i have just book in for new cam belt, because i have been told the belt is out one tooth (timing on pump) which is common when changing belt, i have just bought mine with new belt fitted,pay peanuts you get monkies,you have just confirmed my diognosis,thanks hope this helps
Edited by 5143 barry
Hi all
:unsure:
Hi all
:unsure:
Hi Barry - cheers for the reply, guess I will get it checked out hearing that. The job was done by a garage I've used regularly for years, although yes, I do get away with paying them peanuts!!! They did seem to struggle with it a bit!
Rgds Glenn
  • 4 weeks later...
Hi all
:unsure:
Rgds Glenn
Hi all
:unsure:
Rgds Glenn
Barry - FYI, the pump timing was out, not sure by how much but I took it to Toyota themselves and they sorted it out. Now runs good all the time - shame really 'cos I'm selling it now!!!!!!!
