could anyone tell me if the 4x4 dash lights are different on different models ? mine is a new shape surf kzn185 3ltr, on my other ones i noticed it displays in green if you are in four wheel drive or not when you click the buton on the stick but on my new one it dosen't tell you, only the diagram in the middle, at the top centre lights up flashes and so on but no green writing telling you you're in 4x4. dont know what to make of this, is the thing not working or is it different display , this is getting on my nerves not knowing ?? :help:
The KZN185 has 4wd normal and 4wd Locked, only use the normal 4wd setting on tarmac, so when you press the 4wd button the centre light will flash until it's fully engaged, try using it a few times as they do get a bit sticky when not used much.
Hope this clears things up for you.
