HI
NEED HELP.
I HAVE A TOYOTA PREV AT MY GARAGE WHICH HAS AN PROBLEM.
THE PROBLEM IS IT KEEPS BLOWING THE FUSE FUSE NUMBER 29 IN OWNERS MANUAL ( WHICH IS FOR THE CHARGING SYSTEM FUEL INTAKE AND MULTIPORT SYSTEM.)
I HAV CHANGE THE FUSE AND THE CAR STARTS UP FINE BUT WHEN I TAKE IT FOR A TEST DRIVE THE FUSE BLOWS AND THE CAR STOPS AND WON'T START, WE THEN CHANGE THE FUSE AND IT WILL KEEP ON BLOWING UNTILL THE CAR COOLS DOWN.
<_< HAVE TESTED THE STARTER AND ALT BOTH ARE FINE. HAVE CHANGED THE RELYS AND DISCONNECTED THE LAMBDA SENSER STILL THE PROBLEM REMAINS. AFTER REDING SOME TOPICS THINK IT MIGHT BE THE 2 SENSORS ON THE MANFOLD IF SO WHERE CAN I GET THESES PARTS CHEAP??
CAR IS AN M REGISTRATION 2.4 PETROL.
ALL ADVICE WOULD BE GRATEFULL .
Is the coil getting very hot ?
Cheers
Pete
