I met the owner of a lovely modded MR2 turbo the other night. His car is one of the nicest I've seen and is running 380bhp with nitrous. Anyway, he has managed to get his front lights half popped up, it looks pretty cool I think.
He said all you have to do is open the bonnet and locate a blue box which is behind the passenger front light. You pull it out then get someone to turn on the lights so that they pop up, just as they start to move up you pull out the switch on the box quickly, this makes the lights stop in their position. Apparently they will remain in this position, even when the lights are turned off. Worth trying as it doesn't cost anything :P .
also if you play with the light stalk, turning to the 1st position after turning to off you can make em stop halfway down without pulling any fuses.
or you can click your stalk to position 2 when they are going down, does the same.
(position 1 being off, 2 being off, 3 being sides and 4 being full)
Don't you just love synchronised replies... :D
So in other words... we all knew :D
lol..... thought everyone knew this already.
I didn't, but whats new there, so your not the only one to find out recently dawolf :D :P
My instructions were easier to follow! :P
Ah that's okay then, I was starting to feel rather silly :D
or you could install a pivot headlight controller, so you can set the height from inside the car :)
