Again Lowering
Gregg
:P
Right i understand the case of TTe Springs and i can use my old shoickers on a 30mm drop
But.. this is my fear the front is going to end up lower than the rear, as this is how the car sits :(
is there anyway i can have the rear slightly lower?
hi gregg,yes there is. mine is dropped 30mm all round and you are correct that it sits higher at the rear (i tow a speed boat so this is a plus for me as it would be to low at the back otherwise).
another company sells 35mm spring kits for the avensis (google search would probably find them) so u could put 30mm on the front and 35 mm on the rear but u would probably have to buy 2 complete kits........not cheap.
Where did you get your springs from to lower your car? Approx. how much did it cost?
