Just wondering how easy it is to fit Rev 3 rear lights on a Rev 2? Do they need any modification? Also, is the wiring easy enough to sort out? I know I'd need the Rev 3 centre panel. Thanks.
It's easy only mod is that you need to knock your steel c/panel in abit where
the rev/lights are.And the wiring is isn't hard to do, also the boot lock isn't
long enough, but a new one from MrT isn't that dear. :thumbsup:
yup hold the panel in place and youll see the light units come over two 'humps' in the bodywork
either whack them with a rubber mallet or 'as me and a friend did it' put a piece of doubled up corrugated cardboard in place and use a lump hammer, will save scratching and nackering the paint
support the other side with your hand or the hammer will bounce
