Daft Question, About Washers
Karma Supra
Hi Folks... heres one for ya...
I should know with doing design at uni and all that but I didn;t tend to listen too much in the engineering lectures... :bookworm:
I Am replacing the cam cover screws on my supras, the stock ones always die, and cause oil leaks everywhere, the heads get rounded and they are a pain, I have sourced some nice allen head maching bolts in stainless... :D
The stock ones have a rubber washer/grommit that helps stop them from undoing when subjected to vibrations, which I'll not be able to use...
If I use standard washers they will undo, if I over tighten them I'll kill the oil seals, so short of using thread lock, what can I use???
Are split washers the right ones for high vibration low torque bolts???? :wacko:
Ta! :thumbsup:
The Vibration washers we used to use in work were like these -, VC180532-01.jpg
.:Bigger Pic:.
Used to use them when I was a plant fitter on the main carrier bolts for a Motabert rock breaker, they might be a bit over engineered for a cam cover. ;)
Im cautious.. :D
Those split/spring washers should be fine, although the ones with the jaggered/star inside a circle would probably be better ;)
Cheers guys I'll have a look!!!
Might as well wait untill I do the tappets, fit polished cam covers, and fit nwew oil seals! Preferable before "the Ring"
Giddlepin You used to work with plant??? I don;t supose you know any contacts that want a fleet management system do ya? :D
The last plant company I worked for six years ago, ran a Priestman Tiger and a Mustang 120!-------What do you think? :lol:
