1998 Avensis
JHY_258
:ffs: HI EVERYONE
NEW TO HERE BUT WOULD REALY LIKE HELP. I JUST BOUGHT A 1998 (SREG) AVENSIS THE INTERIOR LIGHT WAS A BIT ERRATIC SO I TOOK THE COVER OFF AND THE BULB WAS IN BITS, SO I REPLACED IT AFTER DOING SO ALL THE INTERIOR LIGHTS HAVE GONE OFF AND THE CENTRAL LOCKING HAS STOPPED WORKING, HAVE CHECKED ALL THE FUSES UNDER THE BONNET AND THE HIDDEN ONES IN DRIVERS FOOTWELL AND ALL SEEM TO BE OK.
CAN ANYONE GIVE ADVICE ETC WOULD BE ETERNALY GREATFULL
:ffs: HI EVERYONE
That is funny, since I had to check my fuses last night due to the fact that I got out of the car and couldn't lock doors using key fob and the interior light wasn't working nor was the door switch in car. I realised that the central locking had to be at fault, so started searching. Additionally I was getting a beeping from under the bonnet. :eek:
I think it's true that the interior will stop working if a fuse has gone to tell you that there is a problem, could be wrong there but hey won't be first time. <_<
I went through all the fuses as you had done and couldn't find one out. But when rechecked them a third time I found one out. It was in the engine compartment one and if I remember rightly it was the one labeled DOME. It was such a subtle blow i missed it, so all I can suggest is go through them again. Good Luck :thumbsup:
:thumbsup:
:ffs: HI EVERYONE
CHEERS i tried as you suggested and low and behold YOU WHERE RIGHTTHANKS A LOT :thumbsup::thumbsup:
CHEERS  i tried as you suggested and low and behold YOU WHERE RIGHTTHANKS A LOT  :thumbsup:  :thumbsup:
Glad to hear that. :group-cuddles:
  • 5 months later...
I had exactly the same problem with my 1999 (T) 1.8GS (interior light not working, remote central locking then not working when I took the (broken) interior bulb out whilst trying to replace it and and the beeping noise).
I checked the Dome fuse and there was a subtle blow in it. Replaced it and all's now well. :bye:
Discovered in the process that the driver's door doesn't lock with the key (lock is goosed) and that I can only lock the car via the keyfob! Not spending money repalcing it, however!
Many thanks.
