Mk3 Supra Turbo
supra-lex
hi
i have i bit of a problem with my 1989 supra turbo
sometimes and most times its started to start on 5 cylinders then come on to 6 cylinders a few secs after and run fine.
i checked oil and water if mixing
i checked radator for oil traces
the water system does not over heat or pressurise
there is no smoke out the exhaust
ive changed the spark plugs and new leads
it went away for a while but has now come back
ive compression test the engine and carn't anything wrong.
i can start the car sometimes and theres no problem but if i start the car and drive it to the shop etc turn off the car and leave it for 5 min go and start it up and it starts up on 5 cylinders then comes on to 6 sylinders
so i would bo most grearfull for any help and info you people could give me because i now have no idea whats going on with it
many thanx :help::help:
Dodgy coil pack?
thanx mate ill try an fine a coil pack from somewhere and try that do you no of any one selling one or any breakers that will have one
cheers :thumbsup:
Penguin has a spare one for the mk4....may fit the mk3... ;)
link
I have a spare Mkiii turbo coil pack, but there are differnt types!! I take it yours is the one with the seperate earthing strap? I also have the ignitor to match.
Pop the leeds out and look around the plugs, is there any moisure or oil there? the old 7Ms tend to leak oil and get the tops of the plugs oily causing misfires!
yes mate thats right i have the one with a single wire which comes from the plate on the coil packs and earths on nut on the inlet manifold.
ive checked the leads and replaced them i did have oil done in the plugs before and just replaced the cam cover seals
the car ran find for about 3 months but now the problem has come back starting on 5 cylinders then few secs back on to 6
if you have the coilpacks i need ill have them off you
if pm me or email me we can sort something out
cheers :thumbsup:
  • 2 months later...
Could also be something as simple as oil leaking from your rocker covers and drowning your cyl. 6 plug, at the back end of the engine.
