New Fasia
Dougs
Can anyone tell me how you remove the ciggy lighter when replacing the lower dash pannel
Help its getting dark new i should of waited till tomorrow :!Removed!:
I had trouble removing mine, I just got a flat screwdriver and kind of dug away at the plastic untill it poped out. But then I had to glue it back in on my new fascia, as it was a bit loose.
I did try hitting it with a hammer aswell but it didn't work, still wouldn't budge,
for the price I thought it would have come with one
You have to remove the black plastic casing on the inside just pulls off
Then if you look inside from the front you'll see a small plastic square you have to push that in whilst pushing it from behind this will remove the inner metal part
Then you'r left with the main cassing which hase two small clips right at the base just push these in and it pops out
Then just put it back in reverse order
