Exaust/cat Problem
SpudBoy
My mate has a MR2 Roadster and recently had problems with his exhaust / cat convertor. The garage he took it to said that MR2's have 3 cat convertors but has repaired his car and only put one on, saying this was ok. My mate now has a warning light on in the car which means there's a problem with the cat convertor / exhaust.
So, does an MR2 have 3 cat convertors, and will it run ok on just one??
I have no idea about cars etc so sorry if any of the above doesn't make sense! :wacko:
The car should run fine - you dont need a cat to run a car. :yes:
you just need a cat to pass an MOT, its all about emisions. ;)
As long as his emisions are below required, it should be ok.
What does the light on the dash say / look like ? :huh:
its pobably that hsi exhaust gas temp sensor or oxygen/lamba sensor is not installed / disconnected ?
Ok, cheers dude.
I don't know what the light's like, sorry! Thanks for the help, I'll let him know :thumbsup:
