Alloys
Gregg
Had a search through the site and it has not really yieled much information :help:
Basically, i want to get some 17's for my avensis im also haveing some 40mm springs for it
Now i need information on offset and pcd for the avensis setup,, or at least some idea on a range of wheels which will fit the car correctly :)
HI THE OFFSET ON THE AVENSIS WHEEL SHOULD IDEALLY BE BETWEEN ET 35 TO ET 38,BUT MY SE 2000 AVENSIS COMES WITH alloys WITH ET 39 AS STANDARD
PCD IS 100 X 5 WITH A 54MM CENTRE BORE
MAKE SURE THE CENTRE BORE IS 54 MM AND NOT ANY LARGER AS IT WILL CAUSE LOTS OF PROBLEMS WITH CENTERING THE WHEEL ON THE HUB
AS FOR A 40 MM DROP UNLESS YOU INTEND REPLACING THE COMPLETE DAMPER UNITS ON THE FOUR CORNERS AS WELL, STICK TO A 30MM DROP AS A MAXIMUM
Cheers
ill bear all that information in mind  :D
dear toyotamaniacs
greetings from outside uk :)
due to coming of spring an important question has risen.
can anybody tell what is the maximum measure of a tire if it fits on a 7,5x16 wheel and the car is t22?
will 215/55 fit? 7,5" wheel needs a minimum 215 imo? below 55 can´t be bacause of the great (not) roadconditions we have in Tallinn, EST
thanks,
teet
my 1995 celica gt4 has 215/55R16 fitted onto 16x7.5 wheels , it does however knock the speedo out by around 4 mph slower than what im actually travelling.
interested in fitment under T22 but thanks for the reply.
rgds,
T
HI
TRY A 225 /50X 16
THAT SHOULD COVER THE 7.5 RIM AND STOP ANY SCUFFING OF THE ALLOY WHEEL
AND BECAUSE YOU WOULD USE A 225/50 THE SIDE WALL OF THE TYRE WOULD BE SIMMILAR TO THAT OF THE 55 SERIES 215
