rhaines is right. To keep trouble free my serviceman adviced me changing oil/filter every 7,5k km, but I drive it hard.
you are certainly right with the TS but do the same as me and you quick
all the car even the last subaru, just install this
Toyota Corolla TS with bemani supercharger kit, 272PS, 295Nm
http://www.bemani.ch
Not sure about the flat changes but I guess once you have confidence it is all ok.  :eek:
As the high lift cam is set to come on at 6200 revs you will need
to flat shift in order to keep the engine there. If you are tempted to
ease off on the throttle during the gear change then you will drop
out of the zone.
Technically the gear ratios do not overlap, but the momentum of the
engine will give you a nice kick when you let the clutch back in and
hey presto we are back at full attack again :D
The fact that the Toyota engineers did not set the high lift zone to start
lower down the rev range simply says to me that this is how the car
is meant to be driven :D :D :D
Cheers
Paul.
I like the way you think Paul........ :yes:
Might have to try the flat shift, but not sure if the salesman would be so happy for me to try it on the test drive
Thanks for the comments guys. I enjoy reading these forums.
