Tachometer
RossP
Does anybody know of a decent tachometer? I'm not after a 5" or 6" job, just a 52mm or 60mm one. I'd prefer a good brand name as well, such as Blitz, HKS etc. The Vitz comes without a tacho in the dash, and it's starting to get on my nerves a bit now...
Cheers,
Ross
OK, I've decided against the eibachs :crybaby: I've ordered some Apex springs instead. Mainly due to the fact that they're the only ones I can afford until my Dad comes out. Has anybody got these, and what do they think of them?
Chris (earpl) has 'em on his TS.
http://toyotaownersclub.com/forums/index.p...20&t=26989&st=0
Yves.
  • 2 years later...
Cheers,
Ross
I put a sunpro in my 2000 american Echo, they have a small whiteface guage. The OBDII scan plug under the dash has a pin for the tachometer, I hooked my wire in there and ran the rest of the wires to the fuse box. On the OBDII plug on my car the tach pin is the first one on the bottom row. I'm sure your car is different but check out this wiring diagram and see if it is close.
http://www.geocities.com/psx_play5000/EchoSpecifications.pdf
