New Brake Discs?
Hi all, Basically as the title really,
I have ordered new Pagid pads all round but was thinking of getting new discs as well. How do I know if I need new discs or not? Is there a check I can do? I'm not that technically minded, sorry.
thanks for any help,
Cheers,
Michael.
I have ordered new Pagid pads all round but was thinking of getting new discs as well. How do I know if I need new discs or not? Is there a can check I can do? I'm not that technically minded, sorry.
Cheers,
Michael.
A nice and simple check you can do is to run a finger from the middle of the disc outwards to the rim. If there is a noticeable 'lip' to the disc (which you will feel with your finger) then you could probably do with some new ones. :thumbsup:
Make sure you do this before driving anywhere as the discs get damn hot!after just a short trip!!! :eek:
Hope that helps
You can measure the thickness of the disc, also check for excessive wear / scoring.
As for how thick the disc should be, I guess that depends on the discs you have on there :yes:
BGB - Brake system
sorry, dan, could you be more specific with "lip"?
If I havn't driven the car for a few days and pull away, the brakes have seized on and when it releases and I look at the disc, there is an imprint of the pad on the disc. Don't know if that helps at all but its a nice little story.
Michael.
sounds like a possible sticky caliper.your discs from new will be around 30 mm thick , the lip can occur within 500 miles so isnt much of a guide .if your caliper is sticking you would feel it through the steering wheel on light braking ( vibration ) , if you do have a sticky caliper you need to sort it before putting new discs on as they wont last long before they warp.a caliper service kit from toyota is about £25 , new recon calipers can be bought from www.brakesinternational.co.uk £65 , with discount for your old one.
ps- do you speak of the front or rear calipers ???
Michael.
Oh come on!!! obviously if there is a ridge where the pads wear on the disc and where they dont. <_<
cmaster you,ll be suprised at the non mechanical people who ask questions here , what seems to you the obvious is a pandoras box to others. :thumbsup:
