Window Wiper Creaking?
albundy
hi there my window wiper has started creaking wen its raining at first i thought it was the rubber but i now realise its the arm its self any ideas wot this is?
Mine is creaking too (rear) I think it's the rubber :(
Try a bit of wd40 on the spring, ensuring you do not get it on the rubbers or screen..
If that doesn't fix it your 02 Corolla will still be under warranty (Assuming you can meet all the conditions) so take it back to a dealer and get them to fix it.........
I replaced rubbers on front blades last month on my 02 CTS, as i couldnt find complete blades locally (easier job). Had to widen 'lugs' to make rubbers fit.
Rear was also 'creaking' but it is all plastic...so took rubber out (brute force over ignorance) and put back ar*e for elbow...
It's been perfect since :thumbsup:
