P0171 Engine Code
PNH
I have 2000 corolla ce the engine light come on and the error code from the OBDCII was P0171 - System to Lean (Bank 1). I am collage student and doesn't have much money to spend any suggestion that i can fix this problem by my self well appreciate?
Thanks :help:
http://www.obd-codes.com/trouble_codes/gen...ygen-sensor.php
In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
Inspect all vacuum and PCV hoses, replace if necessary
Check for a dirty fuel filter and proper fuel pressure
