Carina E Rough Idle Lack Of Power
leachy
:( hello anyone know if you can clean idle control valve by blocking off the pipes going into it instead of de pressurising fuel system as haynes manual says plus draining the radiator.Is the gasket liable to break or should it be ok plus when the 4 nuts are undone and item is pulled off what does it look like? Many thanks for any help on this topic.Leachy :D the car is a toyota carina 1.6 e k reg lean burn.
