Squeaky Clutch
hi guys,
every time i press the clutch down on my tubby (which is currently in the for sale section ;) ) it makes a squeaky noise... wasn't too bothered first but now i took it into town and its pretty annoying - i think people outside the car can hear it also!!
Any ideas..? any1 else had the same problem... what needs doing (WD40'ing..???)
Rash. :thumbsup:
the clutch cable just needs greasing mate, nothing serious. anyone who knows their sh1tttt will be able to do this for you.
yeah it's annoying, mine used to do it :)
Corolla Gti's do it as well ocasionally ...and we have hydralic clutch mechanism :lol:
Which cable mate? Thought ours was hydraulic...
It is :huh:
hi guys,
Rash. :thumbsup:
Mine does that too, I've tried everything to fix the problem but nothing works. I've had the same thing on other cars, I'm not sure that much can be done about it, just turn the stereo up!!!
It is :huh:
the clutch pedal then... anyhow, mine stopped doing it after about 3-4months :P
mines squeaks too... although not all of the time.
mine also squeeks, but not straight the way only after so long
AAaahhh the Old Clutch Squeek topic rears it's head again :lol::lol:
Sorry, Shaf, just greasing the clutch pedal alone does not cure it on every MR2. My Rev3 had a squeeky clutch and the pedal was the first thing I treated, but it didn't cure it. My girlfriend Rev2 had a squeeky clutch and putting some WD40 on the pedal and mechanisms didn't cure it.
I read a fix for it a while back, but can't remember where it was or how to do it now... :(
I'll have a search through my old MKII folders and see if I stored any links in them...
My MKI also has a squeeky clutch from time to time. I just live with it.
It's the release arm inside the gearbox thats doing it, not sure if you can grease it up with the box still on the car. maybe there is an inspection plate where you can get to it.
J
it cant be greased properly, but spraying into the housing with spray grease and a straw attatched can sometimes cure it. no luck for me though.
