Has My Gear Box Gone?
BLOODUK
I recently had problem with the master clutch cylinder, having problems changing gear because i couldnt bring the clutch pedal up.... Had that sorted and it was changing gear fine for a day, but today i came off the motorway and did much slower driving through residential roads but it seemed like the gear lever found it hard to come out of gear when i put the clutch pedal down to the floor. Mainly Second and third!
I got home put the car in neutral , turned off and tried the gears ... it seems very hard to come out of second and third gear and wont go into reverse. But first to second is fine.
Ill give the car a quick drive in a min and test it out
Just took the car out for a run , and it changed gear fine... wierd wonder why it was playing up after the motorway trip
