Need For Speed
robo
need some advice on how to up bhp on my gen 7 190 , can any one help please got about £300 to spend. :help:
also has any one got any prices for a good set of brake disk front and back mine a
little bit rusty and pitted. :help:
Hi mate,
£300 isn't going to be enough to get extra power out of the 190 I'm afraid. Due to the mapping there are no reliable chips out there to reccomend. I wouldn't spend your money on a chip as I doubt ou will get any significant gain. An exhaust and intake is likely to increase the power more than a chip but even then you are only looking at perhaps 8 BHP. It has been proven also that unless the intake is correctly fitted (to ensure it gets genuine cold air and not relfected enine heat) the gains provided are less than actually drilling the stock intake.
Check out the forums on http://www.celica-club.co.uk/
This topic has come up quite a bit in recent months on TOC! so if you check the GEN7 section of the forum you should find some sound advice.
Good luck :D
if you've only got £300 - spend it on your brakes.
no good doing anything to make it go faster, unless you can stop when you need to :thumbsup:
