Door Speaker Guide
seveer unaek
excellent! sticky now! or add to guides sticky post.
and about the dynomat/soundproofing. This can be good for crisp sound but adds weight to the car which slows you down :P Perfectly fine without it.
oh and yes, you should be able to use normal screws and not rivets (for those who do not have a rivet gun).
The guide really helped me to get the courage just to yank the door panel off once the screws were taken out! I was paranoid I'd maybe missed a sneaky screw somewhere.
I recommend using bolts with nylon lock nuts if you are not using rivets. :thumbsup:
Must just be me and my !Removed! comp but i cant get the link to work and very much need that guide! Help!!
Good luck in getting behind the bolts to apply the nut... :D
Rivets.. Gun only cost a couple of quid for a cheapy.. :thumbsup:
Looks like a pretty tip top guide miate. Will be looming forward to using it when i complete my interior conversion! :thumbsup:
Must just be me and my bloody comp but i cant get the link to work and very much need that guide! Help!!
The guide is in MS Word format so you will need a program that will read MS Word documents.
top write up mate, always handy to have some instructions there in case things go wrong  :thumbsup:
We need a guide to tell people what way round to put their new wheels on. Isn't that right chuck? ;)
Excellent guide Keanu, I shall be using this to investigate how my Speakers are fitted!
Should also come in handy for my next car! :D :thumbsup:
Used this when I did mine - gave the confidence to start in the first place.
The rivet gun with rivets shouldnt cost you more than a fiver - and you KNOW that rivets arent gonna come loose.
  • 11 months later...
Hi sorrie to bump this thread but was wondering if the dash Speakers and front door Speakers are connected as one Front r dash and r door are combined ? as Im not getting any sound from the door Speakers and tweeters. I have opend up the headunit n had a peep at the back and only see 2 sets as Im guessing for the front ?saying that do you know the colours of the speakers frm the car as I only see white/black ,White n Grey,Grey/black cheers its Japo Vitz 99 1.l
I have opened up my doors and they do have Speakers connected to the wires of the same color of the dash ones but still no sound coming from the doors I have takens pic and this is the only connector coming from the dash for the headunit as it only has 2 sets of wires for the sound Pink and purple for the left side and blue n green for the right and the rest for powering the headunit .. is this right ?again its a 99 1.L Phase 1 I think, my dash only has one knob for the heater. I had thought it would have seperate wiring for the doors
Ah man the boost guage looks class there! Cheers for the hint :P As regards the car, yes, it is a Phase 1 and about the Speakers I really don't have a clue so i'm not going to be of much use, sorry
