want to know that info with standard ECU and turbo, Startlet GT turbo 95
mine has upto 0.8 bar before
but after change turbo unit, it down to 0.6 bar now
does the early and later turbo has different pressure?
turbo pressure should be the same on all standard 4efte ct9 turbos, regardless of age.
0.6 bar is correct for a standard ct9, maybe you had a hybrid turbo before or a different actuator fitted.
