Bolt Sheared Off In Hub Ideas Please
majormark
My daft sister and wife!!!! They had to change a wheel because of a flat tyre, but tried to remove the bolt turning it clockwise!!! :ffs: It sheared off. :crybaby: Would anyone have any ideas to an easy solution to remove the piece stuck inside.
Cheers
depends on type of stud, if its pressed in from back then you will be able to knock stud out and replace just that 1, is yours a gen 5? Sure someone else will no if not!
Can you get 2 nuts onto the sheard bolt? if so do that and itll lock the 2 together. then you just get a socket onto them and it should pull the bolt out.
Get yourself to Machine Mart and buy a set of Stud Pullers ( about a tenner ). Drill a hole through the broken bolt, twist the puller into it and it comes out as if by magic !
Rich
