I have a Toyota Hilux Surf SSR-X 2.4 limited turbo diesel with a major problem.It decides to stop as i am driving it and then refuse to start again.The pump is fine and the switch on pump has just been replaced and the relay is fine but no one seems to know what the fault is and now i am desperate as when it is running it is fantastic.Please can anyone help me : :help:
air leak on the fuel filter ???? or an airleak on an injector fuel pipe ??? who knows !!!!! :thumbsup:
diesel filter could be dirty would cause hessitation and poor running replace filter or could be water in the filter they normally have a drain at the bottom off filter 2 let water out
Thanks to both lots of advice so far but i have already checked and tried all of that.Had filters replaced also.Any other ideas?
Have you checked for a fault code.
thanks but still of no help.Any more ideas?
What year is the truck, is it a 2LT or a 2LTE ???
Have you checked for the fault codes that I sent you a link on how to check.
