Pleeeaaase Help! Driveshaft Problems
TomK
My CV joint blew up in the corolla, so i had to replace the driveshaft. I got one from the scrappy from the same engined corolla etc etc and fitted it, it fit fine.
But the new one has a different diameter thread for the hub retaining nut
so the old nut and washer dont fit, i kept the nut from the car i took it off at the scrappy, but the nuts different, and there wasnt a washer :s the nut is like a nut and a washer moulded into one so to speak and wen u tighten it up it wont rotate.
:help: I'm stuck, surely you need a washer dont you?!
please help
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
