Was doing a bit of testing over the weekend. Here are some details for you ..
Running 1 bar boost, no air scoops.
Off boost
Air intake temps : 15/20 degrees
IC intake temps : 50/70 degrees
IC out temps : 20/30 degrees
Ambient engine temps : 50/80 degrees
On boost
Air intake temps : 20/25 degrees
IC intake temps : 70/150 degrees
IC out temps : 30/55 degrees
Ambient engine temps : 80/130 degrees
Then with WI on boost
IC out temps : 25/35 degrees
Ambient engine temps : 80/110 degrees
Rough remembering there .. getting a few other tweaks and then will be re-trying.
sounds good m8.
shows that water injection really does work. are you using a methanol mix in it?
Nope, that was just water .. no Methanol.
One lap of the ring where I couldn't get over 120 on the back straight due to it being too hot, then the next lap with WI she got back up to about 135 ..
Was much warmer on the 2nd day are those temps from the 1st day or 2nd day bud?
-Z
-Z
Both .. and also general driving over the last week.
go to a model shop and get some methanol ( make sure its pure methanol, not mixed with casteroil)
makes quite a bit of differance, mix it 50/50 with water. also bumps up your octane a bit too
I'm usually a Halfords screen wash kinda guy .. but I'd forget before leaving at 5am for the ring ..
A got it, decent range of results then!
Shoulda asked, had a bottle in the car fella!
-Z
carefull with screenwash as some can bugger upyour pump
ERL aka Aquamist recomend using methanol based screen wash in their systems
Always best to run the WI system with some methanol in the system if only to prevent freezeing in winter as ice wil really mess up the pump.
