Reseting The Ecu
Pumba_Levin
I was asking for my mate Gen 6.
Which fuse is to be unpluged to reset the ECU setting? Is it the fuse no.6? Help needed. Thanks.
Fuse box - Engine Bay 1
Fuse box Engine Bay 1 Legend:
F1 Starter motor
F2 Hazard lamps
F3 Horns
F4 Bridge link to F5, F6 & F7
F5 Audio system
F6 ABS control module
F7 Interior lamps, load area lamp, clock
F8 Headlamp - left
F9 Headlamp - right
F10 Spare
F11 Spare
F12 Engine coolant blower motor
F13 Air conditioning condenser blower motor
F14 Air conditioning system
F15 Main circuits supply
F16 Main circuits supply
F17 ABS
F18 Alternator charging system
F19 Airbag
F20 Injection system
1 Engine coolant blower motor relay I
2 Air conditioning condenser blower motor relay
3 Horn relay
4 Headlamp relay
5 Starter motor relay
6 Engine control module relay
take the earth off the Battery for 30 seconds if you're unsure.
Thanks for the reply mate... But, he has alarm security system install, which will cause big problem to reset the alarm after disconnecting the power supply. Any more option to go for?
Thanks. ;)
try f20 , dont forget to press the brake pedal twice after removal.
Thanks mate. But, why pressing the brake twice? I don't have any knowledge in that, can u explain please? Would like to learn more about Toyotas. Cheers.
pressing the brake gets rid of any charge that may lurk in the system ,keeping the ecu memory alive.
