Just bought a 2000 4Runner. Fogs didn't work and had to change both bulbs. Notice quite of bit of white powder (corrosion perhaps). Anyone have this problem?
Also, how do you aim the fogs?
For fog lights:
Park the vehicle 25 feet from a wall on a level surface. Measure the distance between the center of the
auxiliary light and the ground. Place a horizontal mark on the wall at that height.
Visual aim is made with the top of the fog light beam 4 inches below the lamp center at 25 feet with the lamp facing straight forward.
For driving lights:
Park the vehicle 25 feet from a wall on a level surface. Measure the distance between the center of the auxiliary light and the ground. Place a horizontal mark on the wall at that height.
Visual aim is made with the center of the driving beam hot spot 1.5 inches below the lamp center at 25 feet with the lamp facing straight forward.
