Lamp Washers And Side Lights
LORD_ED
im guessing these 2 are on the same fuse as lamp washers dont work unless lights are on but which fuse is it, and if its not a fuse any suggestions
gotta be a fuse if the side lights are off too . i dont think they will wash the lights when they are off .i mean why would anyone want to :thumbsup:
The washers will only work when the lights are on, but it should be a fuse if they're both not working - if you can't find a fuse diagram just pull them out one, by one until you find a blown one :thumbsup:
