I know how to remove the steering wheel (even down to just loosening the nut so I don't break my nose - ta Bibbs :yes: ) but can i get the bugger off? Not a chance, it just won't budge, been pulling on it for ages (ooer), anyone got any advice?
Cheers.
Posted (edited)
Have you hit it on the sides??
What I mean is if you sit in the car, and hit the wheel on the left & right
Sides in turn sometimes it's loosens it.
Edited by Christine & Paul
I'll go and try it now, I feel like hitting it to be honest :angry:
Let us know how yougo on.
Paul
Cheers Paul, giving it a beating worked like a charm!
Glad you got it off. What are you replacing it with??
Just a later revision one...
The only trouble is my indicators have stopped self cancelling which is rather annoying :ffs:
loosen off the steering wheel nut and turn the wheel till it sort of 'clicks' into place then tighten up the nut again, this should sort out the indicators.
I'll give it go tomorrow Hou, cheers.
Got it sorted now, I hadn't put the 'brass' horn connector ring over the pink collar thingy so the lugs on the collar weren't connecting to the back of the wheel.
Cheers all,
Adam.
