Apexi Safc Now £100
starletsy
SAFC is about the best piggyback with will adjust fuelling only.
The S-AFC is a fuel computer that adjusts fuel/air ratio by modifying the airflow meter/MAP sensor signal. The S-AFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500-RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The S-AFC is capable of monitoring and replaying the following data channels in Numerical, Analogue Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %.
Full fitting and wiring instructions are available on the apexi USA website.
Simon
Has it been sold now? I would like to purchase it off you if it hasn't. :)
