i have fitted a bosal towbar on my wifes granvia cost£100.00
most motor factors sell them
watling quoted me £500.00
you will need to drill 2 holes in the chassis because the last 2 holes
have not been threaded but indentations are there
a normal power van witter bar will not fit because the exhaust
silencer is bigger on a granvia the bosal design allows it to fit
hi, i fitted 96-on power van tow bar from towsure,
it fit ok on my granvia, no need to drill any hole,
the only thing i need to do, is bend the exhaust mount,
to stopped the tow bar hit my exhaust box
I spotted one of these for sale in bournemouth.. first time I had ever seen one... and I was impressed with it too.. had a look round and looks great!
I noticed it was Permanent 4 wheel drive.. what sort of consumption figures do you get with these??
i also fitted a towsure tow bar to my 1995 granvia, i had to drill 2 holes which was not difficult to do, infact fitting the tow bar was quite simple, but altering the exhaust is a major problem which i have to sort out soon, as the exhast rattles quite badly on the tow bar, i may have to bend the exhaust, or put cuts in it to allow it to bend and weld it back up, and then alter the rear exhaust bracket to support it,,,,,,,,,,,,,,if you have a small welding kit and a bit of confidence, you can do it yourself, i do hope someone benefits from this information, if you require any further information, email me on scorpiomann1951@hotmail.com
i have also fitted a cam belt,,,,,,,,,,that is not difficult either
