I Got A Poorly Mr2
my mr2 has been stood for along time and it seems poorly, engine sounds fine but when i drive it makes noise from somewhere, think clutch is well goosed but there also noise when i build up speed, it seems to have lost its nippy life, anyone know what could be wrong.
if shes been sitting, probably ignition stuff - plugs knakered, leads damp, dizzy wet / damp, try checkingin them / changin. bad plugs can cause bad performance, and missfire etc!
hello, just seen your post on cb.com and was going to reccomend joining here.
if you still have problems next week let me know and you can swap a few bits over from mine to see if you can find the fault.
mine was a non/rough starter when i bought her and it turned out to be the coil pack. can try mine when it has had its clutch done next tuesday
