Power Steering Fluid Level
n00bie
Hiya folks long time no hear.....
Got another N :eek: B Question.....
My Power Steering has been degrading over the past few weeks and got stiffer...
Where under the bonnet do I check for the power steering fluid level ?
Many thanks in advance.
n :eek: b
n :eek: b
look at the back of the engine, as if you looking from front of bonnet it to the back at the left
There are 2 reseviors up there.. one is break fluid, the other is power steering fluid.. both should be full.. get em checked.
The reservoir is right on top of the pump, it's metallic and has a crenated cover. The cover has a dipstick attached that is marked with "HOT" and "COLD". If you have just been driving check the level against the "HOT" marking, if it's been standing for a couple hours check against the "COLD" marking. Use ATF (Dexron II or III) to fill up if needed.
Yves.
