Squeeky Clutch
ytsport
:( my clutch starting to make a squeeky noise, it happen before but got it fixed while it was getting service. does anyone have this problem aswell and wat did yous do???
thanx
thanx
Mine was doing this
Replaced the clutch fork & clutch cover as it was warranty, But sometime its just where the slave cylinder touches to clutch fork
If its still under warranty let your dealer sort
if not you need to remove the slave cylinder which isnt a big job & clean the contact point on the clucth fork
