I have a toyota emina
when moving an invertor I blew the main fuse under the bonnet 50a I have replaced this but still have no indecators, heater, fan,dash lights, int lights
If somebody has a fuse translater it would be most usefull :help:
Gidday Mate, I hope im of help.
The fuses you may be after live above the heater controls. Yes thats where they should be. The cover should lift upwards or on some its part of the speedo cover as well. Good luck!!!
